Drawing Rectangles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Seems simple, I know, but I'm having trouble consistently drawing rectangles. I draft a lot of mechanical piping (specifically in Civil 3D because we also do pipelines) and I typically use rectangles to draft the pipe rather than two lines so I can easily move, adjust lengths, etc.
I have always dropped in a flange, or something with the pipe OD, and created a rectangle based on that. I use Object Snap Tracking to track the opposite side of the flange and manually enter my pipe length through the keyboard. 99/100 times it'll draw the rectangle with the correct OD and length, but every once in a while some setting changes and it instead draws the pipe to have the diagonal length match my keyboard entry. Pictures below for reference.
My question is - what setting causes it to do this? I've searched far and wide for the last couple years, intermittently as it occurs, to try to find a solution. Eventually it fixes itself and I go on with my life, but it still bugs me.
Started rectangle at top of weld neck of flange, using bottom of flange to track to the right, enter 1.5 [ft] on keyboard
The result, the diagonal of the rectangle is 1.5 ft. Normally it makes the length 1.5ft and the width matches the flange weld neck.
