Drawing properties opens for every file
We are using AutoCAD 2015.  Every time I open a drawing file I get the drawing properties dialog.  How do I shut this off?
If this needs a lisp file, does someone have one for adding to: C/Username/appdata/roaming/autodesk/autocad2015/r20.0/enu/support?
Thank you.
john.vellek
Hi @Anonymous,
Do you have a LISP routine or add-in installed that might be calling this feature DWGPROPS? This is not normal behavior.
You can try a Reset Settings to Default or log on as a new user to see if the problem reappears.
John Vellek
Thanks, John,
Yes we are using Archibus.  So, their program must be the culprit, I am assuming...seems I will need to contact them...
john.vellek
Hi @Anonymous,
Try logging on with a new user account on your machine. Then start plain AutoCAD. Does the DWG Props still appear?
John Vellek
Thanks, again.
I am on a network and cannot do this. I sent the folks at Archibus an email as well.
