Drawing opens only on left half of the screen in modelspace
lieselot_christiaen
Observer
lieselot_christiaen
Observer
Observer
When I open a particular drawing, only half of the screen is used.
Other drawings use the entire screen.
Restarting the software and laptop didn't help.. any sugestions?
0 Me gusta
Responder
Soluciones aceptadas (1)
696 Vistas
5 Respuestas
Respuestas (5)
pendean
Community Legend
Community Legend
Set GFXDX12 to 0 (that's a zero) and see if your display issue goes away.
You also want to ensure your AutoCAD is fully updated, your ABOUT command in the program should show 2023.1.5
0 Me gusta
paullimapa
Since it only happens with this one dwg and not others try running the Audit command. Or open this dwg using the Recover command to see if that makes a difference
Paul Li
IT Specialist
@The Office
0 Me gusta
Valentin-WSP
Solución aceptada
@lieselot_christiaen ,
Maybe you need to set it to one viewport:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
lieselot_christiaen
Observer
Observer
Thanks for all the help! I switched to 2 Viewports and then back to 1 and it's OK now.
steve_mazza
Thanks for posting this.  I ran into this problem on a new DWG file recently.  How the problem occurred was, I used the WBLOCK command to extract linework from a drawing with modelspace split into 2 viewports.  When I opened the new block, the linework was on the left half of the view area, and the right half was just "dead" - no viewcube, and no way to interact with that side of the screen.  So it was like having 2 viewports, but not quite.
Using the +VPORTS command and selecting "Single" did not fix the problem.  But selecting 2 or more viewports, and then setting it back to single, did fix it.  This worked from both the +VPORTS command, and the View menu.
0 Me gusta
