drawing not updating in viewport
dmf14
Observer
dmf14
Observer
Observer
my drawing is not updating in the viewport, what can I do?
0 Me gusta
Responder
396 Vistas
8 Respuestas
Respuestas (8)
pendean
Community Legend
Community Legend
Not enough information: please elaborate in more detail, or share your DWG file here.
0 Me gusta
Valentin-WSP
@dmf14 ,
I agree.
You may also want to review these similar topics.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
dmf14
Observer
Observer
here is the drawing. I have tried "display line weights," I tried changing the scale of the lines, I tried regen, nothing is frozen, not sure what else to do. Thank you!
0 Me gusta
dmf14
Observer
Observer
hi i posted a link below, thank you for these articles. none of them quite worked. any thoughts?
0 Me gusta
pendean
Community Legend
Community Legend
Thanks for the file: not seeing any issues here, can you explain more
0 Me gusta
dmf14
Observer
Observer
so I have changed the line styles (some are dashed, etc) but those styles are not displaying correctly. as you can see they are all solid lines but they are not supposed to be.
the other issue is that the drawing will not update in the lay out space
0 Me gusta
ennujozlagam
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Set-sc...
0 Me gusta
vinodkl
Hi @dmf14
If the line are appearing solid in viewport then click inside of viewport and type in the command " PSLTSCALE" and set it to "0" and then regen. You would now see the line as they appear in model space :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
