@dmf14 ,
I agree.
You may also want to review these similar topics.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
here is the drawing. I have tried "display line weights," I tried changing the scale of the lines, I tried regen, nothing is frozen, not sure what else to do. Thank you!
hi i posted a link below, thank you for these articles. none of them quite worked. any thoughts?
so I have changed the line styles (some are dashed, etc) but those styles are not displaying correctly. as you can see they are all solid lines but they are not supposed to be.
the other issue is that the drawing will not update in the lay out space
Hi @dmf14
If the line are appearing solid in viewport then click inside of viewport and type in the command " PSLTSCALE" and set it to "0" and then regen. You would now see the line as they appear in model space ![]()
