Drawing not showing up
samanak_samin
samanak_samin
I tried adjusting different things but the drawing for this design won't show up
cadffm
are you talking about Layouts? Which one?
or Model tab?
This is what I see (no problem, or I don't understand)
Please explain more
Sebastian
samanak_samin
I don't know how I should edit my settings so that the drawing shows up on the page. As of now, it isn't.
cadffm
This is the Plot Preview!
Would be a good idea to write what you are looking for : PLOT 😉
Answer: Your LAYER are set up to NO PLOT
except Layer0, but the only 3 mistakes on Layer0 are off the plot area.
Start command LAYER and change the PLOT setting of your custom layers to your needs
(Defpoints and 0 are standard layers, don't edit standard layers)
Sebastian
pendean
Community Legend
Community Legend
See attached @samanak_samin I removed all your settings (like setting most of your layers to never plot) that counter your intent.
Are you aware your DWG is set for FEET as units? It's unusual to opt for that when drawing floor plans: what are you actually trying to use for units exactly?  No way your house is 8500feet long and 8000 feet wide
samanak_samin
No, when I hit control P to make a dwg to pdf. The dwg does not show up on the page at all.
cadffm
Please, save your current .dwg and share
Sebastian
