drawing not showing on autocad
No aplicable
0 Me gusta
Responder
258 Vistas
3 Respuestas
Respuestas (3)
BeKirra
Please upload a sample drawing file here so people can help.
This symptom will be caused by varied reasons.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
0 Me gusta
ennujozlagam
hello, try to pick first point on the screen and drag your line anywhere  it will appear or post your drawing here. thanks
0 Me gusta
imadHabash
your image tell us - only - that AutoCAD waiting for Specify first point . you may need to check your Layer status,please from LAYER command make sure that your current layer is not turned OFF .
Imad Habash
0 Me gusta
