drawing distorted
drawing distorted
UNISOL
drawing distorted
UNISOL
I've just activated my suite on my laptop.  when I open an existing dwg it's as if the graphics card has gone insane. the dwg elements seem to have been exploded so that there are bits all over the place with lines joining.  dwg is recognizable but fragmented ...?
imadHabash
HI,
I suggest to disable hardware acceleration from 3DCONFIG command.then reopen your CAD file.
Imad Habash
UNISOL
Yes, that worked. Thx!!
ennujozlagam
@UNISOL hello , try to set value of your VIEWRES to 20000 and see if helps. thanks
Alfred.NESWADBA
just as additional info: if disabling hardware acceleration solves issues then you should know that the driver does no communicate well with AutoCAD (using DirectX).
As long as you only work 2D, it is ok ... but whenever you are working 3D you are losing a lot of power, so I would try to find a driver for your graphic card which works better with AutoCAD and you can activate the hardware acceleration!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
UNISOL
Excellent, thx.  I played around with it and the only box that needed to be unchecked was the "smooth line display".  I will, however, take your advice and see if I can get an update to the driver.  Thx.  Thor
