Drawing a rectangle with dimensions not coordinates
I must have accidentally changed something on autocad as I have lost the ability to just draw a rectangle by entering my measurements. It is now asking for coordinates. I have read through tips but not found anything to match my issue. I never had to enter "D" to do this, it just was set up to automatically do length etc. I am desperate to get this feature back - please help.
It appears to be different in each file. Previously, I just selected rectangle icon, clicked a point in model space and then two boxes appeared and I entered measurements. Now I just get coordinate option.
Vinayv4v
Turn on F12 (Dynamic Input)
or
Type DYNMODE <3>
Cheers,
Vinay Vijayakumaran
Thanks - my F12 key does not appear to do anything which is odd (I use F3 and F8 all the time) - but I typed DYNMODE and <3> and it restored the setting.
Thanks so much for helping. I am assuming there are 1-3 different settings or something...
Vinayv4v
Yes.
Refer the link below for details regarding DYNMODE Variable.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Cheers,
Vinay Vijayakumaran
How do you get the menu bar at the bottom with the "f" commands to show up? I never know whether my functions are on or off. Thanks
Vinayv4v
Right Click on any of the options (eg : dyn) then turn of the use icons menu from it.
Cheers,
Vinay Vijayakumaran
