Draw polyline to nearest point
No aplicable
I am a complete novice to the world of coding, especially within AutoCAD so please forgive my naivity. I want to achieve a scenario whereby I could click on a block, and a 3d polyline would be drawn from it's insertion point to a perpendicular point on a polyline (within a given area) from the block.
Would this be achievable? What would be the best language to use to achieve this? I was just hoping for a push in the right direction at this stage and I will go away and do some further research on the matter.
Cheers
Matt
0 Me gusta
Responder
Soluciones aceptadas (1)
463 Vistas
3 Respuestas
Respuestas (3)
dbroad
Yes, it can be done. I would use LISP.  For more assistance in coding, try posting in the Customization newsgroup.
Architect, Registered NC, VA, SC, & GA.
0 Me gusta
Kent1Cooper
@Anonymous wrote:
.... I want to achieve a scenario whereby I could click on a block, and a 3d polyline would be drawn from it's insertion point to a perpendicular point on a polyline (within a given area) from the block.
Would this be achievable? What would be the best language to use to achieve this? ....
Depending on what you mean by "(within a given area)," that might be achievable with a mere command macro, i.e. if the User would pick for that perpendicular point.  Perhaps something [untested] as simple as this:
^C^C3DPoly INS \PER \;
[That would end the 3DPolyline after the perpendicular, but if you want to continue from there, omit the semicolon at the end, or even the space and last backslash and semicolon.]
But if the "given area" would be somehow pre-defined or saved into a variable or something, or if you want it specialized such as to have a particular prompt used, or if you want the User to be asked again if they miss on either pick or don't pick on a Block or something, the AutoLisp suggestion would be better.
Kent Cooper, AIA
0 Me gusta
No aplicable
Solución aceptada
Thanks both very much for your help.
I have started a new thread here.
Cheers
Matt
0 Me gusta
