AutoCAD Forum
Draw Order
2 REPLIES 2
tgperret
294 Views, 2 Replies
Draw Order
We just updated from 2016 to 2020 and the draworder does not function correctly.  It doesn't always bring items to front as well as items in front and behind of other items.  Is this a software glitch and is there a fix?  We have many seats here but my task are different to others and I am the only one using this feature here, so I don't know if this is a problem with others.
2 REPLIES 2
Alfred.NESWADBA
in reply to: tgperret
please start command _ABOUT, it shows the exact product version, if it's different to that one you should install the latest update:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
vinodkl
Try updating AutoCAD 2020 with latest update and see if it fixes your problem.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Forma Design Contest
AutoCAD Beta
