Draw order not working.
Hi, i have recently up graded to Autocad LT2019 and I've had problems with draw order ever since, I've now down loaded a couple of service packs that has sorted out issues with hatching in dynamic blocks being wrong but now when i insert blocks or even add dim lines when i try to change the draw order to send one block beneath another nothing happens at all the function just doesn't work.
S.Faris
Go through this post : Draw Order in 2019 Not Working
Confirm if the value of your TREEDEPTH is set to 3020.
SALMANUL FARIS
this matter is now resolved thank you.
s.borello
Please mark @S.Faris  answer as a solution, as it will help others who may have the same issue.
