Draw contour lines from XYZ data
Hi guys,
I have a bunch of X,Y,Z points, see attachment.
And I am wondering how to make contour lines using the data.
Any advice?
Valentin_CAD
This can be done using AutoCAD Civil 3D.
You must first bring the excel data as Points, then create a surface - see links.
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-...
https://knowledge.autodesk.com/support/civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Civi...
After importing the points, choose the right format from the Surface >Definition >Points Files "Add" option.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
