& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hi all,
I am writing to find out how to wrap the purple band around a metal post in the 3D AutoCAD?
Note: It is not a continuous band.
Thank you for your prompt reply.
The design has been modified to have the cyan band wrap around the post. Pls see snapshot for your reference. I do see the imperfect surface of cyan with purple lines within the cyan. Currently, the radius of the purple post is 40mm and the radius of the cyan curved band is 40.1mm. Have I done anything wrong?
I drew a vertical line and then use "sweep" command to generate the curved band by following the helix.
Thank you for your kind feedback.
Try THICKEN command on the wrap, a minimal thickness will do.
Hi @Anonymous
Type in the command "FACETRES" and set it higher value like 5 or more to increase the smoothness of the object and see if that solves your problem 🙂
Another option is to maintain just the one object, but IMPRINT a new face that can be assigned a different color.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
