DRAGMODE on/off toggle with Macro (or LISP?)
Haider_of_Sweden
Haider_of_Sweden
could someone please help me to create DRAGMODE ON / OFF toggle with Macro, or maybe LISP
Thank you in advance!
Replies (16)
john.vellek
Hi @Haider_of_Sweden
Why not create three buttons in your CUI?  I added one to one of the menus.
This is the syntax:
John Vellek
imadHabash
if i understand your need right ... i suggest to try this :
  • from MANAGE ribbon tab select RECORD or type in the command line ACTRECORD .
  • a red ball will appear beside your cursor to notify you that you're under record action.
  • now type in the command line DRAGMODE and select ON.
  • from MANAGE ribbon tab select STOP or type in the command line ACTSTOP .
  • a dialog will appear -----> in Action Macro Command Name enter any unique name that meet your need.
repeat the previous steps to record DRAGMODE = OFF. NOW you have a customize commands name will be active and always whenever you need it.
Hope that it's help haider ..
Imad Habash
tramber
'dragmode $M=$(if,$(and,$(getvar,dragmode),2),0,$(+,$(getvar,dragmode),1))
This one togles between the 3 values DRAGMODE can have. and transparently
tramber
'dragmode $M=$(if,$(or,$(and,$(getvar,dragmode),1),$(and,$(getvar,dragmode),2)),0,1)
Even simplier !
Haider_of_Sweden
Even simplier !
Yes, this looks like what I am searching for.
However, if I put it in an .SCR file and drag it into AutoCAD, it wont work. Do you really start with 'dragmode?
tramber
' before DRAGMODE allows you to click as you excecute any command. But the fact is that it wont show the effect during a draging.. action.
Nevertheless, Il should learn you that scripts are pretty different and don't allow any toggling, dont' they ?
' doesn't exists either in a script, as far as I know.
My solution stands for a buttton. Scirpting DRAGMODE is strange to me but you are welcome to do it with no DIESEL, no '
tramber
Well, sory to publish again but the question of the transparency in script may be asked. I should remember but it's time for me to go and we 'll talk about later on.
Hope I helped.
B
France
Haider_of_Sweden
Unfortunately, this worked neither a shortcut nor button.
Maybe it is not working because of the transparent command? Although, I think transparent DRAGMODE might be rather cool instead of using ^C^C
tramber
It's about midnight where I live, I have to go Smiley Happy
Yes it works good at my place.
Don't know what is going on...
^c^c is not an obligation.
' is cool
Again, I don't know what could be wrong for you with this humble macro
Haider_of_Sweden
Your code resulted in "Invalid option keyword."
GETVAR gives us 0,1 and 2, but the input should be AUTO or OFF.
This is how I solved it;
^C^Cdragmode $M=$(if,$(and,$(getvar,dragmode),2),OFF,AUTO)
A note regarding transparent command in this context. The DRAGMODE effect won't be actualized until next time anyway, so using a transparent command is unfortunately of no use here. I was hoping it actually toggled DRAGMODE on the fly, not toggling it for next time's use.
Thank you for laying the ground for me.
tramber
Well, at least it is a solution.
let's dig it before i fall asleep !
What version are u running ? I'm on 2015 (edited).
And i like to try my 'macro. Look, it's funny to draw a polyline and to click on your button.
God. How is it that it doesn't work as I thought it would on any version ?
Haider_of_Sweden
I am on 2016.
For me it's not interesting using it while drawing polylines, but rather when moving heavy objects. Therefore I don't need the command on the fly but just a quick hotkey under my fingertips instead of typing the command manually.
Toggles are my favorites 🙂
tramber
Why don't you put the macro in an accelerator then, rather than in a button ?
Anyway, it is still a mystery to me that you seem not to be able to get the same result
Ni______(on)ce We       (off)ek-end !
Haider_of_Sweden
What is an accelerator?
By the way, I put it in a button, just for test purpose. Now I run it as a shortcut.
tramber
My solution is intended for a button. Not for a script. This is why the ' should work.
Did we misunderstood ?
An accelerator is found in the CUI interface and corresponds to a CTRL+C, for exemple.
You may know CTRL+L or CTRL+B, that's an accelerator too (I'm not under English version but I think that it is the word)
Have a look in CUI, it is easy to find.
You can create one, with a '
Smiley Wink
tramber
Apologize,
It's named Shortcut, probably what you've done.
Accelerator is the technical word.
