Drag and drop to original coordinates
kristof_b1
kristof_b1
When opening a .Dwg drawing then Ctlr A and just copy paste it,
i can paste it to original coordinates into another drawing,
But is there a possibility that i can just drag and drop a .Dwg file into autocad and place it on the original coordinates?
i know i can use the other drawing as a Xref but i need to have the induvidual lines from the drawing and not as a block.
Thanks in advance
Kristof
Valentin_CAD
@kristof_b1 ,
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Kent1Cooper
That depends on the insertion base point of the drawing you're dragging in.  Let's say that's at the default 0,0: when you drag-and-drop a drawing into another, you are asked for an insertion point, and if you give it 0,0, everything ends up in the original locations.  [But yes, it then needs to be Exploded, which at least is simpler than XREFing it and then Binding.]  If the drawing you're dragging in has had its insertion base point [read about the INSBASE System Variable, and the BASE command] changed to something other than 0,0, you would need to know what that is to get it to land at the same place in the target drawing.
There's a way in the INSERT command to bring something in pre-Exploded, but I don't know of a way to apply that in a drag-and-drop operation.
Kent Cooper, AIA
