Double click on .dwg file not working if AutoCAD is running already
byzodvoid
byzodvoid
Community Visitor
Community Visitor
OS: Windows 10 2016 long term (work computer)
CAD: AutoCAD Mechanical 2019 (23.0.46.0) based on AutoCAD 2019 (P.46.0.0)
Problem: Double click on .dwg file focus the autocad, but no drawing file is opened
Reproduce:
1. Close autocad until it fully exit.
2. Double click on A.dwg, autocad start automatically and opens A.dwg
3. Double click on B.dwg.
Expect:
Autocad opens B.dwg, now I have two tabs of drawing: A.dwg and B.dwg
Actually:
Autocad was focused (become the active and front window) but nothing happened else. Now I have only one tab of drawing: A.dwg
Additional info:
1. dwg files have icon and thumbnail, looks like associated correctly
2. Right click on dwg file and select open with > AutoCAD Application is not working, neither do AutoCAD DWG Launcher
3. "OpenLaunch" entry is set to correct exe location ("C\program files\Autodesk\autocad 2019\acad.exe" "%1") in HKCU\SOFTWARE\Autodesk\DwgCommon\shellex\apps\{F29F85E0-4FF9-blahblah}
Thomas_Stuehle
Hello @byzodvoid
Welcome to the AutoCAD Forum.
Please check the article "Multiple drawings cannot be opened in AutoCAD". I think this is the behavior your describe right? Please check according to the article if the system variable is set to 0.
Did the post helped you and answered your question? If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
imadHabash
Hi and Really Welcome to AutoCAD Forum,
I could not stop myself from being liked in a way that presented your problem. 👌
Imad Habash
Alfred.NESWADBA
Update AutoCAD to 2019.1.2 which is (currently) the latest update for the AutoCAD part.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
