Door openings not showing?
I used the Box tool to create door openings.  But the actual openings do not appear.  They are filled.
How can I make the openings display, like as shown in the second image?
jggerth
did you run the SUBTRACT command?  looks like you simoly missed that, and have the boxes and the walls both occupying the openings
I did a Solid Subtract, but this changed nothing.
pendean
Community Legend
Community Legend
Doesn't look like you did, or it was not the thickness of the wall to make a difference.
imadHabash
the most easiest way for a such practice is to draw lines over the body of the model,then use PRESSPULL command (see attached image).
Note: POLYSOLID command will help you to trace your 2D walls.just fill the data (H,W,and J)
Command: POLYSOLID
Height = 3.0000, Width = 0.3000, Justification = Center
Good Luck..
Imad Habash
