Don't show some 3D solids in AutoCAD 2013 but in AutoCAD 2014....2018 it's fine.
praila
praila
can anyone help me to understand why some 3D solids disappears or not show in AutoCAD 2013 version.
But when I open this attached file in newer versions (2014...2018), it looks fine.
Any ideas how to fix this?
I would be very grateful for any response.
0 Me gusta
Responder
Soluciones aceptadas (1)
455 Vistas
6 Respuestas
Respuestas (6)
imadHabash
if you move all the 3d solid object 250 to up direction;any differences?
Imad Habash
0 Me gusta
praila
I tried, still missing those elements.
0 Me gusta
john.vellek
Hi @praila,
I no longer have AutoCAD 2013 installed so this is hard to test. I don't see anything unique with the drawing however. Can you try to copy and paste into a new file to see if that makes any difference? You might also consider a Reset Settings to Default in AutoCAD 2013.
John Vellek
0 Me gusta
praila
Hi John,
Thank you for trying help me. Yes I tried to copy >  paste in new drawing, also wblock and all other variations but unfortunately...
I'm working with 2017 version and could be that this solids I made with newer version and somehow affected visual drawing reading opening it with 2013 ?
I'm creating piping supports library and testing with fresh installed 2013 version and I found this "bug" in several modeled parts.
Maybe there is any way to open this drawing with Inventor Fusion and re-save it to DWG or step files?
0 Me gusta
john.vellek
Solución aceptada
Hi @praila,
I took the file into Inventor and also into Fusion. I have attached the exported files here for you to try in your AutoCAD 2013. Please post whether these make any difference.
John Vellek
praila
wonderfull, it works!
Resume:
best converted files - FromIgestofusion.step, 350MA52_H150 v1.step (became same great solid elements)
medium - 350MA52_H150.iges (because all elements became surfaces)
worst - 350MA52_H150-Inventor_Layout1.dwg (because don't show any element)
John - thanks a lot for your patience!
Now I know the way how to correct those mysterious files. The only question as elements become invisible. I'll try to indicate this in the future.
