Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
doesn't work autoCAD korean IME hotfix
4 REPLIES 4
476 Views, 4 Replies
hello autodesk I'm korean autoCAD 2020 user.
i just downloaded 'update korean IME hotfix' from this web site.
and i follow the manual, to replace [acad.exe]file.
but it doesn't work. i can't run anymore autoCAD after replaced update file.
what should I do?
I send you screen capture
Tags (1)
4 REPLIES 4
ennujozlagam
uninstall the one that you just install and refer to this LINK and see if helps. thanks
in reply to: ennujozlagam
thank you so much. but my problem is it.
I switched language [KOR->ENG] or [ENG->KOR] so many time.
because im korean. so I have to put korean in the CAD drawing.
but sometimes language switch(we have this button in keyboard) button is doesn't work.
also [autodesk] knows this problem.
So, they made update file. and I downloaded. and I followed manual.
but it is not work...T^T
ennujozlagam
if you update korean language, you need to update also the english language? if autodesk know's about this issue then you need to contact them and explain to them your current situation. thanks
okay I will. thank you for reply🙂
AutoCAD Inside the Factory
