@Anonymous wrote:
Overlapping and zero-length polyline segments are deleted.
→ Directly in other word , overlapping pointed object without dimension are deleted. Right ?
If by "pointed object without dimension" you mean a POINT entity such as is drawn with the POINT or MEASURE or DIVIDE commands, "overlapping" on other kinds of objects, then no, those would not be deleted [unless there are more than one of those in the same place].
A zero-length polyline segment is one with both ends at the same place -- not a separate object, but a segment within a Polyline. To demonstrate, start a PLINE command, pick a point, continue, and somewhere along the way, pick exactly the same point twice in a row [whether by Object Snap or with positional Snap turned on], and continue further. Finish the Polyline, then select it, and in the Properties palette, look at the Geometry section, Current Vertex slot:
If you pick on the little up pointer at the right, you can watch the X marker of the current vertex move around the Polyline. When it gets to that place where you picked twice, the next pick on the up pointer will raise the vertex number, but the X will not move. That's a zero-length segment--two adjacent vertices in the same place.
Use Overkill on the Polyline, with the "Optimize segments within polylines" option checked, and it will report "1 overlapping object(s) or segment(s) deleted." Select the Polyline again, and run through the vertices, and it won't "hang" at that vertex location any more.
Kent Cooper, AIA
