Does anyone know how to change the base point of a block?
Xiao16
Xiao16
I am having trouble with a question as blew:
" 'Palm Tree' block in the block editor and change its base point to -20.28,17.11 coordinates. Close the block editor saving changes in the block. What is the distance between point P and the point on Palm Tree block where all leaves merge as shown in the following image? “
Thanks!
0 Me gusta
Responder
Soluciones aceptadas (1)
3.666 Vistas
18 Respuestas
Respuestas (18)
ChicagoLooper
Distance: 712.99 meters.
I'm guessing you really want to draw in feet and inches. It looks like you accidentally used a metric template, not imperial.
If you print to scale you will have issues. But if you simply want to use print to fit then scale won't matter.
Chicagolooper
0 Me gusta
imadHabash
Click on below image and look where is -20.28,17.11 coordinates appear .
Depending on your inputs ...
If do you want to make a basepoint while you're in block editor try to use Basepoint parameter from Block Authoring Palette .
Imad Habash
0 Me gusta
Xiao16
Solución aceptada
I figured out how to change the base point in the block editor. In the palette, I selected the basepoint, then enter the desired location, -20.28,17.11. Existed and saved the change. The base point changed.
Then, I changed "Decimal" in the Primary Units which is in the dimension style. Then, I got a solution which matches the solution of the question.
I hope my question and my solution could solve someone else's questions regarding how to change the base point of the block.
Thank you for everyone putting the effect on solving the question!
0 Me gusta
imadHabash
With shifted tree position and sloped dimension you may need to review your issue !!!!
Imad Habash
0 Me gusta
Xiao16
This drawing is not a real engineering drawing. It does not describe a real situation. It is a question of a mock exam.
0 Me gusta
RobDraw
You're going to get that answer wrong if you do it that way.
Rob
0 Me gusta
Xiao16
My answer matches the solution that the instructor posted. I mentioned it.
0 Me gusta
tien099
Observer
Observer
It seemed like I couldn't delete or edit a base point that is created in a block because I didn't see it inside the block editor. Today I can see it and was able to delete it. I wonder whether it was a setting got turned on or something when I restarted autocad.
0 Me gusta
pendean
Community Legend
Community Legend
@tien099 wrote:
It seems like there is no way to delete or edit a base point that is created in a block. None of the posts here describe editing an already created base point. Am I missing something? Is this very simple thing not available in autocad?
There are dozens of free LISP and free add-ins that do just that over the decades, have you not had a chance to look them up? I'll get you started here
https://apps.autodesk.com/ACD/en/Detail/Index?id=1203146290307485351&appLang=en&os=Win32_64
https://www.lee-mac.com/changeblockinsertion.html
If you are only wanting to wait for Autodesk to build something in for whatever reason, you can us REFEDIT or BEDIT command do to what you want, or go very old school and recreate the block from scratch.
How would you like to proceed @tien099
0 Me gusta
Kent1Cooper
I'm not quite sure what you are asking.  The base point of a Block is not an object, so there is no such thing as deleting it.  It is a location in relation to the drawn elements in the Block.  You can change its location in relation to the drawn elements, if that's what you mean by "editing" it, in the Block editor.  The wording "a base point that is created" is puzzling to me.  You designate the base point when you create the Block, but that can be by accepting the default that it offers [0,0,0] if you don't specify something different, so in any case it will have a base point without your creating it.  Is the implication that you think the Block doesn't have a base point until you create one, or that you can create additional base points?  A Block cannot exist without one, and can have only one.  But then, everything I've said is about what AutoCAD refers to as the Block's insertion base point.  Are you talking about something else, and if so, can you describe it, and its function in the use of the Block, in different terms?
Kent Cooper, AIA
tien099
Observer
Observer
None of the options are any good. But thanks.
0 Me gusta
tien099
Observer
Observer
Kent,
In parameters menu of the block editor, there is an option to add base point parameter. Once you add that, there is no way of changing it. Read other posts if it is not very clear to you.
0 Me gusta
cadffm
if you are talking about a basepoint parameter,
you are able to MOVE this parameter while inside BEDIT.
Sebastian
0 Me gusta
tien099
Observer
Observer
How? You can't even see the point inside the block editor.
0 Me gusta
cadffm
Like every other object to.
Start MOVE
select the basepoint parameter
or select the basepoint parameter and start move command.
Click first point
Click target point
Done
Feel free to share a sample dwg and tell us blocks name
Sebastian
RSomppi
I, and others, can and you owe Mr. Cooper an apology.
0 Me gusta
Brock_Olly
What a weird thread
0 Me gusta
pendean
Community Legend
Community Legend
@Brock_Olly wrote:
What a weird thread
It happens when "me too" posts a lot.
0 Me gusta
