Message 1 of 8
12:59 PM
already mentioned in your other post, this is a hardware memory fault. Memory on your graphic card or in your system memory if the graphic card uses shared memory.
Hardware needs to be replaced.
- alfred -
none of my other programs are faulty . autocad is the only program.
which other applications do you compare with (which are having such a high display list handling as AutoCAD has)?
- alfred -
please let us continue in this thread. In the meantime there are 3 users with the same issue within one day.
Maybe we find what is equal for all of you ... so please answer >>>there<<< (and send us a screenshot of command _GRAPHICSCONFIG.
- alfred -
Revit.
any other heavy graphic load software's like Lumion SketchUp work absolutely fine
Many users in the forum are facing the same issue after upgrading the graphic driver and the issue seems to be with the new version of the driver so Try to roll back the graphic driver.
