Dissociated dimensions and leaders
I have recently been frustrated while annotating my drawings. When I first place a dimension or leader, everything works properly. The problem arises when I want to modify the dimension or leader. If I wish my dimension to read off a different snap point, I click one of the grips and move it to the new point, and the dimension changes accordingly. However, the dimension has now become dissociated. To remedy this, I must click the yellow check box and confirm the two points I wish the dimension to read off.
The same thing happens with multileaders - if I click the arrow grip and relocate it to another snap point on the drawing, it becomes dissociated.
I don't believe this used to occur although I am not 100% sure. But it is certainly annoying to have to confirm changes in this way twice.
Is there a better method I can use, or a setting somewhere I can change to remedy this?
Alfred.NESWADBA
Sorry, not a solution, but a confirmation.
Using AutoCAD 2018.0.2 I can reproduce this issue (and if my remembering is correct that already was mentioned here sometimes ago) ... and again sorry, I haven't find a simple way around (hopefully someone else find one).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
BeKirra
FYI - Search in HELP in case you need.
1) system variable "dimassoc"
2) commands "dimdisassociate" and "dimreassociate".
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
