Hello All,
I have an issue where the dimension value that is displayed is changing when plotting. It is like the precision itself that changes.
Example: Dimension is 9'-6 1/8" and is displayed as such in the .DWG file. Go to plot to .PDF (or plotter) and the value changes to 9'-6 3/32".
If I go to the dimension and set the precision to whatever value I want then the dimension plots as it should.
Side Notes:
-AutoCAD 2016 / Plant 3D
-Dimensions are in paperspace
-I am not the only user in our group to experience these issues.
-Issues seem to have started recently (maybe due to a Windows update or something else?) and are seemingly random.
-Had an issue a couple days ago where dimension values changed to weird text in the .DWG and a plot. Just double-clicking on the dimension (to edit it) reverted the dimension text to it's correct value. And new dimensions started showing a completely wrong value. Ex: dimension should be 1'-6". It shows 545'-2". At the same time a style override showed up out of nowhere.
Any ideas as to what could be causing this?
Many thanks in advance!
