Display issue of white hatch in model space
Corolla34
Corolla34
I read in another post that one way to achieve white hatch when plotting is to use color 255 and set its screening value as 0. This method works fine in final plot/print-out. However, in model space, it is displayed in white color, which is the same as usual black objects. In the case where there are black objects, e.g. texts, above the white hatch, it becomes very difficult to tell the contents since both of them are perfectly white (unless they are selected and one can judge from the highlight dashed lines).
So is there a way to make a specific color transparent only in model space (in this case, color 255)? Or is there a better way to achieve the same white hatch in layout without sacrificing the discernibility in the model space? Thanks.
p.s. Would wipeout, which I'm not very familiar with, be a solution here?
h_s_walker
Welcome to the Forums
You can't do it a such but here is a workaround
Make a layer and call it WIPEOUT LAYER.
Give it a colour maybe pink and put your hatch on that layer.
Now go into paperspace and make a viewport. Enter that viewport and change the viewport color to true colour 255,255,255
No when you go into modelspace you will see your text. When you go into paperspace you will not see it, BUT it will print correctly
See the attached drawing.
Howard Walker
Left Handed and Proud
Corolla34
Thank you very much for the workaround. Now I'm thinking about how to apply this to the case where the wipeout area is in a block and from time to time I want to change the color of the wipeout area in print-out from perfect white to normal color, say blue.
h_s_walker
Maybe make a layer called wipeout blue, and leave it as blue and then when you need a blue wipeout just go into the block and change the layer of the wipeout/hatch
Howard Walker
Corolla34
It seems to be a solution. Thank you!
