& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
When I select the lines, the display does not appear as usual. That is, the control points and the midpoint of the line do not appear selected, this makes it impossible for me to know if it is selected. Additionally, if I assign a line thickness greater than 0.30, the line disappears. When I change the display style to 3D it is solved, but it is very slow and I cannot work. I attach screenshots.
I have even tried reinstalling the program. Still the same
Lineweight:
First step: make sure your program is updatet to the last version.
Updates available in your autodesk account.
Doesn't solved the lw problem?
See command ABOUT
Share your Autocad Productversion
Grips: Also an issue if you select a line near to 0,0 wcs?
Set UCS to world,
Zoom to 0,0 2000,1000
and draw a line
as test
Sebastian
Try setting command: GFXDX12 = 0
If that doesn't work, use command GraphicsConfig & under 2d Display Settings dropdown select one of the other settings:
If that still fails, under GraphicsConfig disable Hardware Acceleration
PS: Also a good idea to make sure you have the latest Graphics Card driver installed under your Windows OS
@frahine ,
In addition, check these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Turn off hardware acceleration through the GRAPHICSCONFIG command
Hello @frahine
This is a known issue on AutoCAD 2024 and it has been fixed in the update 2024.1. Please update your AutoCAD to the latest update 2024.1.2. This will fix your issue 🙂
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
