display error line selection
frahine
Community Visitor
frahine
Community Visitor
Community Visitor
When I select the lines, the display does not appear as usual. That is, the control points and the midpoint of the line do not appear selected, this makes it impossible for me to know if it is selected. Additionally, if I assign a line thickness greater than 0.30, the line disappears. When I change the display style to 3D it is solved, but it is very slow and I cannot work. I attach screenshots.
I have even tried reinstalling the program. Still the same
cadffm
Lineweight:
First step: make sure your program is updatet to the last version.
Updates available in your autodesk account.
Doesn't solved the lw problem?
See command ABOUT
Share your Autocad Productversion
Grips: Also an issue if you select a line near to 0,0 wcs?
Set UCS to world,
Zoom to 0,0 2000,1000
and draw a line
as test
Sebastian
paullimapa
Try setting command: GFXDX12 = 0
If that doesn't work, use command GraphicsConfig & under 2d Display Settings dropdown select one of the other settings:
If that still fails, under GraphicsConfig disable Hardware Acceleration
PS: Also a good idea to make sure you have the latest Graphics Card driver installed under your Windows OS
Paul Li
IT Specialist
@The Office
Valentin_CAD
@frahine ,
In addition, check these suggestions:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
jayhar
Turn off hardware acceleration through the GRAPHICSCONFIG command
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
vinodkl
Hello @frahine
This is a known issue on AutoCAD 2024 and it has been fixed in the update 2024.1. Please update your AutoCAD to the latest update 2024.1.2. This will fix your issue 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
