Display block names in the drawing
v_harutyunyan
v_harutyunyan
Please help: I want to have field text inside a block that will show the name of that block and update it when the block is renamed. Can anyone tell me if this would be possible?
cadffm
paullimapa
For example:
Open "C:\Program Files\Autodesk\AutoCAD 2026\Sample\Database Connectivity\Floor Plan Sample.dwg"
Read only is ok
Zoom in to a cubicle and double click on RMNUM block which has a single Attribute NUMBER:
EATTEDIT command is executed, then right mouse click on the Value edit box and on the context menu select Insert Field
In the Field window:
Field Category: Objects
Field names: Object
Object type: click on Cross to select object
Back on the graphics drawing window select the Chair block
When the Field window reappears this time under Property select Name & click OK 2x
Back on the graphics drawing screen you'll see that the name of the Chair block is now filled in as the block attribute:
Now when you Rename the Block CHAIR7 with CHAIR8 and then do a REGEN the Block attribute will automatically update
Paul Li
IT Specialist
@The Office
v_harutyunyan
@paullimapa thank you for your clear step by step explanations with screenshots!!!
paullimapa
You are welcome and if you want to automate with a lisp routine to select the block with attribute and then the block  with the name then post here
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Paul Li
IT Specialist
@The Office
v_harutyunyan
@paullimapa please explain how to assign attribute to a block as well. I messed up in this issue.
paullimapa
Lots of video tutorials on this online like this one:
https://www.youtube.com/watch?v=Ar4tPaEZmyY&pp=0gcJCdgAo7VqN5tD
Paul Li
IT Specialist
@The Office
