Announcements
Disapperaing Courser
When performing Copy/paste my courser disappears!
I have to kill Acad.exe in Task Manager and start again!
My version is up to date so no need for SP.
Any ideas?
Replies (8)
imadHabash
If the latest SP have been installed..let's try turning off hardware acceleration.
Imad Habash
Thanks!
That one is already done! Never been turn on!
But the probllem remains!
imadHabash
Follow this >> Link << i hope it's help.
Imad Habash
Emmsleys
Hi @Anonymous,
What version of AutoCAD are you using?
Does this happen with all of your drawings even a brand new file?
Did this just start happening?
Did you apply any new updates to your system?
Were you able to try the suggestions made here
Sarah Emmsley
Technical Support Specialist
Hi again!
Unfortunately the problem is still there!
It happens using Move command!
A icon appears, like in the attechmant, and everything stop working and I have to restart!
Emmsleys
What AutoCAD release are you working with?
Windows versions? 7,8,10?
Do you have a high resolution monitor?
Sarah Emmsley
Hi!
I got AutoCAD 14 1.108.0.0 SP1.
Screen 1920x1200
Windows 7 Enterprise
Vi use this old version of CAD because of our clients!
As I mentioned it happens using Move by mouse left bottom!
BR A
Emmsleys
Okay,
Are you able to test any other mouses?
Does this happen if you use the command line to move or pan in the drawing?
Can you post a file so that I can try and replicate your issue?
Sarah Emmsley
