disappearing xref when moved
created a DWG file(call it file 1) from an IFC file no problems. Xref file 1 into by working file, OK. Move xrefed file 1 in my file, if you select random spot on screen (no snapping) and move horizontally or vertically OK, If you use snaps,
or move diagonally the xref file 1 disappears and I have to undo the move command to get it back. I have tried to xref file 1 into a clean file with nothing in it (no layers or templates)
and it behaves the same.
Has any one else experienced this behavior and find a solution.
