Actually, hwesley3 has 2 threads with similar questions in this forum and he wants to change dim text size, right?
The drawing he was working on is from 3rd party, right?
Based on all he mentioned, I suspect that he is not familiar with drawing scale. Without seeing the actual drawing, you don't know if the creator of the original drawing was using the dimension style on layout, right?
Furthermore, a lot of people don't create objects on 1:1 scale in model space. Do you know this? You can't simply "assume" everything drawn in model space are on 1:1 scale, especially before you see his drawing.
I was trying to help him clarify the real issues by asking couple of questions.
And if he has difficulty for modifying someone else dimension style, it would be much better to create a new dimension style.
Do you know much on dimension style? Do you know how to setup drawing scale? Do you know how to use dimension styles on layout? Do you understand the real issues behind his questions?
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
