Dimensions manager
Dimensions manager
No aplicable
Hi all,
Im using a student version of AutoCAD 2016. I need to Change a setting in my dimensions manager to ISO-25 for a drawing im doing, but i only have the standard option available. Could anybody tell me why this is?
Many Thanks
0 Me gusta
Responder
Soluciones aceptadas (2)
537 Vistas
4 Respuestas
Respuestas (4)
Patchy
Start a new drawing using ACADISO.DWT instead of ACAD.DWT
0 Me gusta
No aplicable
I am very new to all of this, could you tell me what the difference is? Just out of interest.Thanks!
0 Me gusta
Patchy
Solución aceptada
Acadiso.dwt is a template to start a metric drawing.
Use STARTUP cammand and set it to 0.
Make a new drawing and you have choice Metric or Imperial.
Since you already started Imperial unit drawing, use command -DWGUNITS and change your drawing to metric (answer yes to have your drawing scaled)
Then make a new drawing, start with Acadiso.dwt; then save as acadiso.dwg and drag & drop it into your existing drawing, the dimension will appear.
0 Me gusta
Emmsleys
Solución aceptada
Hi @Anonymous
This Autodesk 2016 Templates site has information that you can read over each of the templates.
The site has a brief explanation of available templates.
Were you able to test the ACADISO.DWT template?
Sarah Emmsley
Technical Support Specialist
0 Me gusta
