Dimensions/command bar options
No aplicable
I used to see a command bar (to specify dimensions/lengths) right next to the shape I am trying to draw, and now my only way to specify the dimensions is by typing in the command bar at the bottom. This is very inconvenient for me. How do I go back to having to type in the dimensions right when I try to draw the shape? I tried typing shift+@ but it is appearing in the command bar at the bottom.How I used to see itHow I used to see itNow I only have the option to type the dimensions in the command barNow I only have the option to type the dimensions in the command bar
0 Me gusta
Responder
Soluciones aceptadas (2)
2.416 Vistas
2 Respuestas
Respuestas (2)
imadHabash
Solución aceptada
press F12  or the button DYNMODE in the status bar.
Imad Habash
vinodkl
Solución aceptada
set system variable DYNMODE to "3" or press F12 key
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
