Dimensioning in model space.
No aplicable
I have AutoCAD 2016 out of the box and I'm trying to dimension an object in model space. I'm doing something wrong or something isn't set correctly because when I make a dimension the nodes are on the object but the actual dimension is on the 0,0,0 planes. I then have to move dimension so the extension lines are on the object and then move the nodes back to the original point picks. What am I doing incorrectly?
0 Me gusta
Responder
437 Vistas
5 Respuestas
Respuestas (5)
rkmcswain
I do not understand what you mean by "but the actual dimension is on the 0,0,0 planes"
Can you provide a screen shot or the DWG file?
0 Me gusta
No aplicable
Here is what happens when I try to dimension a box in model space. The nodes are on the box, but the dimension shoot off to the 0,0,0 planes...
0 Me gusta
No aplicable
Too bad there isn't a way to grow the dimension off of the node..
Thanks for the answer.
0 Me gusta
No aplicable
Dimensions land at elev. 0 on the "Z" plane of the current UCS.  Change the origin of the UCS to match the elevation where you want the dims to land.
