Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Dimensional Constraints with Construction Lines?
NateLFO
NateLFO
Hello.  I'm fairly new to AutoCAD, though I have been teaching myself how to use it here and there over the last year.  I am more familiar with 3D CAD platforms like Fustion360 and SolidWorks.
Something that I cannot for the life of me is figure out how do apply a dimensional constraint to a construction line, so if for example, I want a rectangle's edge to be a set distance from a construction line, or if I am placing multiple construction lines in a layer and I want to have set spacing between them, when I try to use the Linear, Vertical, Horizontal, or Aligned dimensional constraints, it will not let me select a construction line, it tells me that it is an invalid selection.  Is it not possible to apply dimensional constraints to/from construction lines?
leeminardi
No.  Trim the construction lines so that they have a finite length and then you will be able to apply constraints.
lee.minardi
NateLFO
Thanks for the reply. It's unfortunate that you can't dimension the spaces between construction lines directly. Luckily, I did just discover the EXTRIM command, so I can place a bunch of construction lines and when I am ready, draw a rectangle for a bounding box and trim them all at the same time.
