Dimension text
radhikamittal_
Observer
Dimension text
radhikamittal_
Observer
Observer
Dimension box is showing but dimension text is not visible when using DIMALIGNED Command and even after modifying text height and size through DIMSTY Command as suggested by your previous suggestions, still the dimension text is not visible.
Responder
291 Vistas
3 Respuestas
Respuestas (3)
vinodkl
Hello @radhikamittal_
Can you please share the drawing and screenshot of what your seeing on the screen, so that we can help you out?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Kent1Cooper
Is this problem only with DIMALIGNED, and not other kinds of Dimensions?  If it happens with all kinds, and with Text/Mtext/Attributes, it sounds you have QTEXT turned ON [the QTEXTMODE System Variable set to 1].
Kent Cooper, AIA
0 Me gusta
radhikamittal_
Observer
Observer
Actually I have checked but the QTEXT Command is also turned off but still
facing the same problem and with all the dimension commands.
*World University of Design*Plot No.1, RG Education City, NH-1, Sonipat
*Website <>* | *Facebook
