I posted about this years ago and dont know how to find the thread so im starting it again. Last time had no solution so years later I have just downloaded AutoCAD 2026 and absolutely cant believe this is still an issue.
Very often when dimensioning a drawing in AutoCAD, i will double click the value which enters into the textbox so I can add some text to clarify what that dimension is. On a vertical dimension, I will add the text below the value. Whenever I do this, the "Dim Lines" don't adjust for the text. "Dim Line 1" is running straight through the text so it looks terrible. The only workaround I have found is a little ridiculous but it works and it is what I have been doing. I go into the dimension properties, and under "Text Rotation" I add a very small value such as .01 so it won't be visible. This automatically causes the Dim Lines to adjust to the size of the text box to look proper.
What the heck is going on here? I cant be the only one that adds text to dimensions? please help!
@sandroVJ8CB Your post title was modified to add the product name and version and to increase findability - CGBenner
