Dimension Text Offset when using \X
greg.youngCXLLN
greg.youngCXLLN
Hi, I am looking for a solution to the inconsistancy in Text offset when using \X in Dimensions.
We use 2mm as our "Text offset" so when I want to put Text under the Dimension line, I adjust the Text offset but nothing happens with the Dimension... see screen gabs below
I was thinking maybe double the offset and see how it looks.... but no dice...?
Has anyone found a work around (without using seperate text) for this?
Cheers
imadHabash
Would you please attache here those dimensions as a .dwg CAD file , for testing ?
Imad Habash
greg.youngCXLLN
Hi @imadHabash Thankyou for taking a look, I am thinking it might have something to do with the dimension style ...?
Cheers
greg.youngCXLLN
@imadHabash I think the problem is within Dim Style. When adding \X it somehow??? doesn't scale the Offset from dim line.... could it be?
Cheers
imadHabash
Thanks for your CAD drawing file ..
Click on below image and see how when you reset your dim text position to origin place , any changes now will take a place.
Imad Habash
greg.youngCXLLN
Genius! thanks @imadHabash
