Dimension text mask
Dimension text mask
can someone help me with this dimension mask. everytime i move the text, it will cover dimension line and the mask became whole...
Replies (11)
zia_rehman
Is it overlapping issue ?
____________________________________________________________________________
Please mark this post "Accept as Solution" if my reply solves the issue or answers your question.
Zia
zia_rehman
Overlapping
Zia
zia_rehman
Video
Zia
its not overlapping. the dimension on top is the default output when making dimensions.  Dimension below where i move the dimension text to the side, but the mask cover the dimension line. I want to know if theres a way that the dimension text will be the same when moving.image.png
zia_rehman
Please Upload your Demo file to take a look on settings you made for Dimensions.
Zia
ВeekeeCZ
So you what to turn off the mask or move a text to the side automatically?
i want to move the text together with the mask without disorienting the dimension line. The dimension line should still be between the number and the text. sorry for my english. It shold be something like this. with text mask
ВeekeeCZ
Then the TEXT OVERRIDE value should look like this:
<>\XEXIT\PLENGTH
thats right, but when you try to move the text to the side of dimensions, the mask will become as whole covering the line that separate the number and the text
ВeekeeCZ
Post the actual dwg with the issue. It seems to me that it is working just fine.
I use "Text override", but didn't know of your trick.
