Dimension Style to Set Current
jayhar
Advisor Advisor
Message 1 of 14
jayhar
Hi all,
How to remove style overrides in Cad file. After saving work file open again Current Dimension Style change to style overrides.
i set extension line beyond the dimension line, that was changing.
watch this video  https://autode.sk/2sxwOVI
i need cad file open Dimension Style set current what i last saved.
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Accepted solutions (3)
Replies (13)
Message 2 of 14
Command "DIMOVERRIDE", then "C" to clear overrides. it will prompt you to select the dimensions that you want to clear the overrides on. This will return all settings to the default that is assigned in the dimension style.
This command on the ribbonThis command on the ribbon
Message 3 of 14
cadffm
And today it isn't so? Your Video doesn't show this fact.. but Ok, then:
These are your own customizations that do that, you should know them better than we do 😉
So, check which adjustment makes the change, search for one of these keywords:
DIMFXL
DIMFXLON
DIMJOGANG
Start searching in loaded lisp files
In APPLOAD dialog you can see which files loaded, i think you will find you personal files.
(You don't need to search in all loaded files, just in the files you forced yourself to load.)
If you founded the file where you change the dimension variable setting and you need more help,
upload the file and we can help more.
Sebastian
Message 4 of 14
jayhar
Hi @Anonymous
Thanks for responses, i already search AKN command for DIMOVERRIDE.  But dimension objects doesn't return to the  dimension style.
Jayhar.M.j
Message 5 of 14
cadffm
1. I am sure DIMOVERRIDE works (Update dimension object properties to the current, saved dimstyle settings.
2. Why you don't take the cool post of this cadffm guy and answer to the question
    >> And today it isn't so? Your Video doesn't show this fact..
    Because we can not see that you saved a dimstyle & file and after re-open the there is a change of dimension variables.
3. You are active in autodesk forums community for a long time, please: Why you don't upload a sample file
     for us to check the (command) dimoverride problem
     It is so simple to help us for a better help to you.
4. Why you don't take the probably correct answer: It is part of your own customizing, start to search what change
     force the change of you dimension variables:
DIMFXL
DIMFXLON
DIMJOGANG
start withe acad.lsp acad acaddoc.lsp and files listed in appload startup suite - if present.
Sebastian
Message 6 of 14
jayhar
Hi @cadffm
Thanks for responses, Click here  see this post, same issue of me.
DIMFXL & DIMFXLON these two system variable already use in Dimension style.
i am using Two layers S-ANNO-DIM & S-RANGE, these two are same Dimension style also.....
DIMJOGANG <90> in AutoCAD settings
DIMFXL <5>
DIMFXLON <ON>
i am just searching for lisp files also
Jayhar.M.J
Message 7 of 14
jayhar
I try DIM OVERRIDE and update Dimension Styles here is no change. After save and close i seen no changes.
I Copy/Past working file to new cad file now its ok. i save file close and reopen, Dimension Styles are current settings now its working.
Jayhar.M.J
Message 8 of 14
Moshe-A
@jayhar hi,
in your video i see a "bad argument type error" i do not know if this is directly relate to your current problem but what @cadffm  was trying to tell you is to look for bad code in your autoloaded lisp files. you can simply do that by Exporting your AutoCAD settings than remove all AutoLoaded lisp file includeing acad.lsp/acaddoc.lsp and what's in appload startup suite than see if the problem still pressist?
moshe
Message 9 of 14
jayhar
Dear All,
I copy past to new cad file, now its ok https://autode.sk/2AReagk
i did not upload any lisp...
Jayhar.M.J
Message 10 of 14
cadffm
@jayhar
One tip: Use only the docked commandline with 3- rows visible!
1. You can see more information
2. We can read more information for you 😉
Now i am guessing you defined a ss:startup routine which have a problem in your first file,
but not in your second file. We can see the lisp error in your first video and the ss:startup
information in the second video.
And again you didn't follow my hints or just not write about your tests.
Now, with the new information:
You should add a enough princ-statement to your lispfunctions and files to find problems easier.
Sebastian
Message 11 of 14
jayhar
Hello @cadffm
Thanks for responding
Last week i upload CirclePolylineSwap.lsp  so error shows any open cad file.
Message 12 of 14
cadffm
You mean you've added the file to start automatically, anyway.
But this is the problem: "anyway"..
I am pretty sure that just loading the (unknown) code of your version of " CirclePolylineSwap.lsp" is not a problem.
You should search and fix all problems
a) the error that appears in all files
b) the problem what you ask about in this thread (perhaps it is the same source problem, but until it is solved we have to think there are two problems)
But without information(logfile[F2]) and data(=files/lsp) it is hard to help ~ and not funny.
Start with undo your last modification.
Sebastian
Message 13 of 14
jayhar
Hello @cadffm,
Here the thread click here
Last month i upload Circle to Polyline .lsp at that time error starts when CAD open new file error you seen in first video.
i reset profile & start autocad second error seen, ss:startup you seen in second video
see the log file in attachments
Jayhar.M.J
Message 14 of 14
jayhar
Hi All,
I Reset to default settings, now no lisp error & ss:startup information when open AutoCAD.
now Dimension Style is Set Current, no style overrides.
Thanks @cadffm i also follow your thread here
Thanks @Moshe-A your information also help me, thread here
Jayhar.M.J
