Anuncios
dimension style manager - save window size?
Gh_man
Gh_man
We have a number of dimension styles we use in our office. Each is described by a long name in the dimension style manager, and to see the full name, one must resize the window. That's all fine, except the window defaults back to it's original small size once it's closed, and must be resized each time. Is there a way to save / lock the window size?
0 Me gusta
Responder
326 Vistas
2 Respuestas
Respuestas (2)
scot-65
Perhaps adjust the default window size?
(***untested***)
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409\Profiles\<<YourCurrentProfile>>\Dialogs\dimension_styles_dialog
Investigate "Width" at your own risk.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
0 Me gusta
paullimapa
I just tried it but that change had no effect.
And after running Dimstyle command, the value will revert back to it's default.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
0 Me gusta
