Dimension problem
451205861
Dimension problem
451205861
My problem is that when I draw something and then put dimensions to it it shows me reversed , for example if the actual dimension is 70 it shows me 07
0 Me gusta
Responder
874 Vistas
17 Respuestas
Respuestas (17)
imadHabash
Solución aceptada
It sounds that you have a wrong orientation with viewcube. Type :
  • UCS command >> World.
  • Now type PLAN command >> double enter.
any changes now if you put dimensions.
Imad Habash
Valentin-WSP
Solución aceptada
@451205861 ,
Welcome to the forum.
Take a look at the link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
451205861
I'm sorry but can you help me with pictures I didn't fully understand do you mean that I should write UCS and PLAN in the lower command bar in the drawing interface
0 Me gusta
imadHabash
Solución aceptada
Type in the command line :
Command: UCS
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: w
Command: PLAN
Enter an option [Current ucs/Ucs/World] <Current>:
Imad Habash
 I think I did as you said but nothing happened to the dimensions or should I do something extra or redraw the drawing or should I re-dimension it?
0 Me gusta
imadHabash
Yes .. after you make what i suggest make a new dimensions now and see if any changes :cara_con_una_leve_sonrisa:
If it's NOT solved .. please attache your CAD dwg here.
Imad Habash
0 Me gusta
451205861
 Nothing has changed:corazón_roto::cara_llorosa:
0 Me gusta
imadHabash
would you please attache here the CAD file for testing?
Imad Habash
0 Me gusta
Valentin-WSP
@451205861 ,
The same issue was resolved applying the suggestion from message 3 (above).
Emilio Valentin
451205861
Does it work?
0 Me gusta
451205861
Thank you, I tried it but it didn't work and this laptop is not mine. I might have a problem with my sister if I change the language forever :cara_sonriente_con_la_boca_abierta_y_sudor_frío:
0 Me gusta
imadHabash
Solución aceptada
As you can see in below image .. every thing is OK!! I have do nothing,i've just open the drawing.
How about the solution in message 3 above?
Imad Habash
So I think the problem is with the laptop itself, so when I send it to my professor it will be fine. Thank you :manos_unidas_para_la_oración: for responding and helping me
Valentin-WSP
Solución aceptada
@451205861 ,
Must be a language issue, since opening in Autodesk Viewer seems good.
Does the laptop use any other language other than English? If so, it may be the issue.
After changing the language, close and restart AutoCAD.
Emilio Valentin
451205861
Thank you also for responding to me and helping me when I have my own laptop I will do what you said :cara_sonriente_con_la_boca_abierta_y_sudor_frío:
0 Me gusta
451205861
Yes it does
Kent1Cooper
See >this< on the same topic.
Kent Cooper, AIA
0 Me gusta
