DIMENSION LINE IS VISIBLE BUT TEXT IS NOT VISIBLE
Alfred.NESWADBA
either change the textsize in the dimension-style, or look to the textstyle used in the dimensionstyle and within the textstyle make sure the textsize is set to 0 (if it's not set to 0 then the dimension can't set it's size for the dimension text).
If all fails please upload the dwg-file and let us know which version of AutoCAD you are using.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
would you please attache here a dwg sample with this invisible dimension text ?
Imad Habash
