dimension insection point, 2 lines and radius
a way of getting tick marks at intersection between 2 lines with a radius. not just a point. but 2 little lines that show where the apparent intersection point is.
Patchy
They are not blocks, not the same length, they drew in the lines using apparent intersection?
You can use Insert a "+" shape block at the Apparent Intersection and explode it to get what you need
or Insert an "L" shape and rotate to the right position.
never thought of changing point style. diffidently one idea. i was thinking it was a dim setting that i just could not find. am now thinking maybe lisp routine . there is nothing special about little lines.
Patchy
This one put a point at the apparent intersection.
