Dim Text with rectangle around the text.
john.p.addy
Message 1 of 11
john.p.addy
Good morning everyone,  I've ran into a issue that I can't figure out on my own.  I know it can  be done thru the Modify Dim Manager for all text.  I have two Dims that I need a rectangle drawn around the text.
now I did find this thread, so either i don't understand it or its not answering what I'm wanting done
PROVIDING TEXT BOX TO THE DIMENSION - Autodesk Community - AutoCAD
These are the only two dims I need this for.
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Replies (10)
Message 2 of 11
VincentSheehan
Change this in the Dimension Style.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 11
john.p.addy
Thank you,  I do know that one.  That puts a box around all of the dims.  I only need it around the 2
Thank you,
John Addy
Message 4 of 11
pendean
Community Legend
Community Legend
@john.p.addy wrote:
....I only need it around the 2
All or nothing is your only choice in AutoCAD: sorry.
You'll need to manually edit the DIMTEXT then find an TTF font that has boxes around numbers to replace your 2 with it if this is a critical need for you. You'll have to dig in your PC's fonts list to find one like that too.
Message 5 of 11
john.p.addy
ok thank you,
Thank you,
John Addy
Message 6 of 11
Simon_Weel
Create a new DIMstyle and use the current one as a copy. Then switch on the text frame and save the style. Select the two dims and set them with the new DIMstyle.
Message 7 of 11
john.p.addy
TO BE HONEST.  I HAVE NO CLUE WHAT I DID TO MAKE IT WORK.  I DID NOT SET UP A DIMSTYLE OR ANYTHING.   NOW I'M CONFUSED.  LOL
Thank you,
John Addy
Message 8 of 11
john.p.addy
YES THAT WAS MY PLAN BUT SOME HOW I GOT IT TO WORK WITHOUT DOING THAT.   HOW, I HAVE NO CLUE.
Thank you,
John Addy
Message 9 of 11
john.p.addy
SO I  FIGURED IT OUT.  IF YOU LOOK AT THIS ONE IT SHOWS THE " TEXT OFFSET " WITH A MINUS SIGN BEFORE THE NUMBERS, IT DISPLAYS THE BOX AROUND THE TEXT.
WHEN YOU TAKE THE MINUS SIGN AWAY IT DOES AWAY WITH THE BOX AROUND THE NUMBERS AS SEEN BELOW.
Thank you,
John Addy
Message 10 of 11
Kent1Cooper
No, it is certainly not all-or-nothing, and it's not necessary to change the Dimension Style definition.  This will force the DIMGAP setting for all selected Dimensions to be negative, to make the box, even if the size of the gap varies among multiple ones so that you wouldn't be able to handle it collectively in the Properties palette:
(defun C:DBT ; = Dimension Box Text
  (/ ss n dim)
  (if (setq ss (ssget '((0 . "DIMENSION"))))
    (repeat (setq n (sslength ss))
      (setq dim (ssname ss (setq n (1- n))))
      (setpropertyvalue dim "dimgap" (- (abs (getpropertyvalue dim "dimgap"))))
    ); repeat
  ); if
  (prin1)
It doesn't matter whether or not the Dimension's text is already boxed.
Kent Cooper, AIA
Message 11 of 11
TomBeauford
This one will Toggle the TextBox On/Off of selected Dimensions
;| Toggle Dimension Text Box to toggle Text offset (DIMGAP) to negative or positive.
https://www.cadtutor.net/forum/topic/68801-help-to-create-blank-dimensions-with-a-box/?tab=comments#comment-555956
Macro: ^P(or C:DimBoxText (load "DimBoxText.lsp"));DimBoxText
   Command line: (load "DimBoxText.lsp") DimBoxText |;
(vl-load-com)
(defun c:DimBoxText ( / ss i obj box)
  (if (setq ss (ssget '((0 . "Dimension"))))
    (repeat (setq i (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i))))
			box (- 0.0 (vlax-get obj 'TextGap))
      (vlax-put obj 'TextGap box)
  (princ)
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
