Dim text spacing.
Dim text spacing.
john.p.addy
Message 1 of 26
Dim text spacing.
john.p.addy
I thought I had posted about this in the past but I can't seem to find it if I did so I'll ask again.
When using Subscript in the Dim, as seen below, the subscript fades into the line below it.  Is there a way to put more spacing between the lines ?
Thank you,
John Addy
Electrical Engineering Tech.
Department of Defense
Replies (25)
Message 21 of 26
john.p.addy
Ok I get I can do that.  Just trying to not do that.
Thank you,
John Addy
Message 22 of 26
dmfrazier
"Just trying to not do that."
Understandable ('cause that's a PITA). But it is a workaround, after all.
Message 23 of 26
pendean
Community Legend
Community Legend
@john.p.addy wrote:
I get if I change the size of my subscript that would take care of that.  If I do that it will not be readable when its used.  Both font has to stay the same size
Sadly, linespacing has never been a feature of the text editor in dimensions. You'll need to fudge a fix, try a forces \X or \U action, or something with black spaces and text sizing. Experiment until you find it.
Best of luck with it.
Message 24 of 26
Kent1Cooper
I haven't changed defaults to get my subscript 1 taller like yours, but the point is:  The image is in the Dimension text editor, and the little white thing between the lines of content is the text cursor in a line between the other two that is set for a tiny text height, and has no character content.  You can experiment with a text height for that intermediate line that will give you the effect you want.
EDIT:  Here's the text-content entry in entity data for that:
(1 . "Q{\\H0.7x;\\S^1;\\H0.07937x;\\P\\P}TEST")
The red part is the tiny-izing of the text height for the middle line [which is actually imposed before the carriage return that makes that middle line, which is the blue part].  The two \\P entries in a row are the two carriage returns, with nothing between them being the no character content of the middle line.
Presumably a routine could be written that would define a command that would just impose the red [with some appropriate number] and blue parts into any Dimension text containing a carriage return that you would select -- all you would need to do would be to pick the Dimension.
Kent Cooper, AIA
Message 25 of 26
Valentin_CAD
@john.p.addy ,
@john.p.addy wrote:
...  Both font has to stay the same size
In that case, your workaround is @Kent1Cooper  suggestions of adding a space and adjusting that space by the text height.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 26 of 26
john.p.addy
Thank you,  I actually never thought about doing it that way.
Thank you,
John Addy
