AutoCAD Forum
Dim Style Problems
2 REPLIES 2
ttaylor01634
248 Views, 2 Replies
Dim Style Problems
So I'm working on a project at work and the Dim style is the same, but they are appearing different sizes. How can I fix that?
2 REPLIES 2
tmccar
in reply to: ttaylor01634
Hi - can you explain the issue in a bit more detail please? Thanks
Kent1Cooper
Welcome to these Forums!
Read about the DIMSCALE and CANNOSCALE System Variables.  They are what control the size of Dimension elements, all other things about them being equal.  I say "all other things about them being equal," because in addition to the effects of those System Variables, a Dimension Style in one drawing can be defined differently from one with the same name in a different drawing, so you should check the definitions of the Styles.
Kent Cooper, AIA
Forma Design Contest
