Dim commande snapping to other extension lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
I'm not new to AutoCAD and I'm facing a strenge issue since 2019 update.
Since the new version 2019, when I work on paperspace the dimensions on Paper Space are no longer associated exclusively with the object drawn on the Model Space despite the fact that DIMASSOC variable = 2
Result: If an object drawn on the model Space is shown on the paper space (Mview) with a scale different from 1/1 then some dimansions are false (see image attached) using Dim, or Diml commande.
Explanation: the dim commande is snapping to the extension lines of other dimensions resulting in dimensions scaled to the paperSpace, when it should normally be associated with the model drawn on the ModelSpace.
Please take a look on the attached image for a better understanding of the issue.
Please tell me the solution if you know it? (for info, I have already explored DIMASSOC, DIMSCALE, DIMLFAC etc. and everything is well setup)
Cheers.
