differing Excel sheets data linked to differing layouts in same drawing not work
Using Mechanical 2016 stripped down to AutoCAD Vanilla
I have an Excel spreadsheet on which I have say 2 different sheets with different names
I have one dwg drawing with say 2 layouts
I datalink one Excel sheet to one of the layouts & then change to the second layout & data link the second Excel sheet to that
I go back to layout 1 & the Excel sheet here has also changed to the second sheet
It seems I cannot have different sheets of the same Excel file linked to different layouts in the same AutoCAD file
I don't recall this happening previously - is there a new setting I missed somewhere?
john.vellek
HI @Anonymous,
Please attach the Excel file and the drawing so I can take a look and verify your results.
John Vellek
I have attached a drawing file with 2 sheets
I have attached the actual Excel spreadsheet I picked the problem up on
On sheet 1 (named 20152050-GA-001) I attached a sheet from the Excel file
On sheet 2 (named 20152050-GA-002) I attached another sheet
Change 1 sheet & the other will change too
john.vellek
Hi @Anonymous,
I took your file and removed the two linked tables and then removed the datalink.
I then created two datalinks: one for each Excel page and named range.
I then inserted two tables - each one linked to it's own datalink.
I can update Excel and the tables respond appropriately.
I am not sure this is how you go through the process but it has always behaved correctly for me when I follow these steps.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
John
Aha - you have hit the nail on the head
What I did was create the first GA then copy that sheet, went to the new sheet & edited the datalink...
What I shoudl be doing is recreating a new datalink for each sheet.
Thanks 🙂
